beaut old item i found, anyone know much about them?
old philipps generator
Tags: None
Wow Jellywrestler!
I haven't a clue about anything electrical, but its mount begs for it to be used. Its too sexy not to...
(My Chief's down tube calipers 1.395, with heavy powdercoating and rust pits: Didn't know better back then.)
Have you any means to spin it up for a check?
....CottenLast edited by T. Cotten; 04-01-2017, 10:56 AM.AMCA #776
That generator is a beaut, Graeme. I have an ABC generator (circa mid teens-early 20s) on my '17 Henderson. I have never seen a Philipps generator, but I love it. I believe those generators filled a need during the transition from gas lights to electric but by the early '20s, most manufacturers were offering factory electric systems, and they had the consumer's confidence (sort of
. As Tom said, you should give it a spin and see if works.
the brusholders are damaged inside, namely the springs that tension them, i'm sure a careful hand could repair these. i picked it up last weekend at a swapmeet as it was just too nice to walk past.
