Help with Identifying this MC in Old picture, and ID'ing an Old Carb
  • midman
    • Oct 2016
    • 53
    I swear I'm gonna stop buying this stuff, but I never do.
    Some of the recent things I cannot ID. Can anyone help.
    First I am trying to figure out what this bike is that is doing what looks like an amateur hill climb in England maybe. My guess is it is a British twin 20's or 30's (bulb horn on the handlebar). Not the best picture but any help would be appreciated.
    Secondly I got this Linkert carb in a lot with some other parts but I can't figure out what it is for (not even sure it is for a motorcycle). It is stamped 81-A. I am assuming if it was for a bike it would be M81-A but I'm not sure.
    Any ideas?
    • 8247
    Midman!
    Its cleaner than the last time I saw it.
    The cable-contolled choke, and the intake studs suggest suggest automotive or stationary use.
    The green paint and throat-venting suggest military.
    The choke detente and cam are Indian-style, and I have a pic of it showing a standard Indian main nozzle, and a very different valve on the bowl, suggesting it was tapered thread.
    The throttlelever, however, is H-D style.
    Can you guess at the bore of the venturi?
    If its 15/16", then its the same as a WLA and similar to my photos (although it appears brass); If 1 1/16", its the same as Indian, if much smaller, its probably for a stationary power supply.
    • AFJ
      • 465
      1930s Ariel single cylinder twin port?
        An American made carb on a British bike?
        • AFJ
          • 465
          I was referring to the first picture of the hill-climbing motorcycle. Midman asked what make the motorcycle might be.
          AFJ
