Not sure where to place this. Would value all input on crankcase oil best for a Nimbus: 4 cyl; 750cc; crank & trans share oil, 1,000 miles on rebuilt engine; no oil filter; babbited bearings. Originally probably 30 or 40W summer non-detergent but is there a better oil today? Synthetic or blend? Bike will be delivered June 2015 from Denmark. Thanks.
Newbie with 4cyl Nimbus...
Doesn't matter that much what you run... just change it a lot.
Detergent doesn't matter...
Is it flat tappet engine? If so, you will want an oil with a ZDDP additive. Depending on where you live... in hot weather, run 10 - w40. In cool weather, 10 W30. But, again, less important than frequent oil changes.
Synthetic is fine, but if it has a tendency to leak... synthetic will make it REALLY leak. And if you park it for long periods, synthetic will run off components more easily than traditional oil. It's fine stuff... but not much better than changing your oil often.
We run Rotella T in just about everything. Not because it's that much better. But I buy it by the barrel.
Cool bike, BTW! I love the Nimbus. Welcome aboard, this is a great group. Post some pictures!
Cheers,
Sirhr
Ditto what Sirhr said - with modern oils you're pretty much good with anything the right wt or range. Frequent changes are cheap insurance. And he's also spot on about the synthetics. Personally I run straight 40 wt in my 1940 Indian 4 unless I'm going on a long run - more than 2 gas stops - in consistent temperatures over 80F. Then I go to straight 50wt. I don't do cold any more... but when I did ride below 50F for extended periods I would go to 30.
If you're not doing anything August 7-9 you and your Nimbus would be welcome at the 54th Annual Meet of the Indian Four Cylinder Club!
Originally posted by RussBees View PostNot sure where to place this. Would value all input on crankcase oil best for a Nimbus: 4 cyl; 750cc; crank & trans share oil, 1,000 miles on rebuilt engine; no oil filter; babbited bearings. Originally probably 30 or 40W summer non-detergent but is there a better oil today? Synthetic or blend? Bike will be delivered June 2015 from Denmark. Thanks.
AFJ
I run 50 in summer and 40 in winter in my four that I had Cen-Pe-Co blend for me with the proper amount of ZDDP. Non-detergent. See if you have a rep near you. They can blend you anything. I bought 25 gallons each and change every 6-800 miles. Cheaper than a motor. Think it was about 3.50 a quart.Last edited by D.A.Bagin; 07-02-2015, 06:01 AM.D. A. Bagin #3166 AKA Panheadzz 440 48chief W/sidecar 57fl 57flh 58fl 66m-50 68flh 70xlh
Hi John:
You mention use of ZDDP in your Nimbus. How much do you add to the crankcase? Any problems with a slipping clutch?
Prior to having oil blended for me I was going to my local hot rod shop and getting 40wt non-detergent oil and blending in Cam-2 engine break-in additive. I was adding it to the qt. and mixing it up before adding it to the motor. This product has high amounts, in fact, too high, of zddp. I called Cam-2 and explained what I was doing and they gave me directions as to how much to add to a qt. of oil to get the desired results. They were intrigued and very helpful.D. A. Bagin #3166 AKA Panheadzz 440 48chief W/sidecar 57fl 57flh 58fl 66m-50 68flh 70xlh
Russ[ATTACH=CONFIG]15483[/ATTACH][ATTACH=CONFIG]15484[/ATTACH]
