Baby bosch racing magneto for harley or Indian?
  • 26harleyj
    • Jul 2011
    • 32
    Hi everyone,
    I'm not sure if i am posting this in the correct place but I just picked up this baby bosch magneto and was wondering if anyone can tell me if it is either for a Harley or Indian or could it possibly not be a racing magneto?
    James
  • 23JDCA 808
    • Jan 2007
    • 688
    A google search:
    http://www.antiquemotorcycle.org/bbo...gneto-question
    Literature; search for FFV
    Bosch Magneto, veteran motorcycle bosch magneto, veteran motorcycle, 1914 triumph motorcycle
    Bill Gilbert in Oregon
    • RichO
      • Dec 2001
      • 903
      42 degree is Indian, 45 degree is H-D
      DrSprocket
      • BoschZEV
        • Jul 2012
        • 527
        Many, but not all, Bosch magnetos have the firing angle they left the factory with stamped on them. But, I can't see it in any of your pictures and, in any case, that was ~100 years ago so the cam easily could have been changed since then. Unfortunately, it isn't possible to distinguish a 42-deg. cam from a 45-deg by naked eye.
        • 26harleyj
          • Jul 2011
          • 32
          Thank you for the replies. I did look all over the mag and could not find the firing angle stamped into the body of the magneto. If i put a degree wheel on the nose of the drive shaft of the magneto, can i determine if it is a 42-deg or a 45-deg?
          23JDCA 808---Those links were quite helpful thanks but still seems undetermined if this is a racing magneto or not?
          James
          • rwm
            • Dec 2006
            • 1302
            i see this style on beemers. the harley and indian ff magnetos have 2 magnets not one large magnet. they also lack the plastic retaining strap by the wires. this dose not mean it wont work for you. it's just a few years newer. the ff mags make a little hotter spark then the zevs. i have no clue if it is better to have 1 magnet or 2.
            rob ronky #10507
            www.diamondhorsevalley.com
            • MMasa
              • 1192
              The FFV "baby Bosch" units were standard equipment on 1927-1929 Harley mag model big twins. All of mine have one magnet.
              Mark Masa
              Mark Masa
              www.linkcycles.com
              • 26harleyj
                • Jul 2011
                • 32
                Mark, thank you for the clarification for the correct application of this magneto.
                James
                • BoschZEV
                  • Jul 2012
                  • 527
                  If you go to the following link you will find my discussion (under the screen name Magnetoman) of measuring the cam to determine the angle between the lobes:
                  http://www.britbike.com/forums/ubbth...849#Post459849
                  When you click on the above it initially will go to the first page of the thread so just sit on you hands for 5 sec. or so until it jumps to the correct post.
