Need Help Identifying this Oil Line Bracket
  • Hollywood
    • Mar 2011
    • 223
    I need help identifying this bracket. This bracket is attached to what I thought was a 38-41 knucklehead oil return line. It has basically the same bends and length except the bend above the bracket doesn't seem quite right. I consulted Matt Olsen who's guess was possibly a bracket to hold an oil control cable on a peashooter. (Thanks Matt)...Anyone else know for sure what it is?
  • Hollywood
    • Mar 2011
    • 223
    Still need help identifying this bracket...
    • Tommo
      • Sep 2001
      • 1321
      On generator equipted 1926 on singles, 28 and 29 H motors and 1930 on VLs it holds the advance and retard control wire onto the oil pipe.
      Look in the parts books under 3393-26, 3393-28 and 3393-29
      Although there are 3 different part numbers I'm sure its all the same clip.
      Peter Thomson, a.k.a. Tommo
      A.M.C.A. # 2777
      • milw.pirates
        • Jun 2007
        • 287
        Both Matt and Tommo are correct for generator equipt. with distributor, on 26 on up singles, holds adv. and retard cable to oil pump line, a hard to find part.
        Ken S., # 6457
        1926- H-D BAF-Peashooter
        1954-H-D Panhead
        • pete reeves
          • Nov 2001
          • 245
          Tommo.
          For a moment you had me worried I am building a 29JDH and do not have a clip like the one in the picture for it .I thought I had missed something. But then I checked the parts book.
          All of the 3 clips you mentioned are indeed to clamp the coil control
          And the picture in my 27-31 parts book has a picture for 3393-26 which could be the same as the one Hollywood asked about.
          But 3393-28 and 3393-29 look completely different from the one shown in Hollywood’s picture.
          Fortunately I do have 3393-28 which is listed for the JDH it attaches the coil to the gear chest not to a pipe.
          Panic Over.
          Pete Reeves 860.
          • Hollywood
            • Mar 2011
            • 223
            Thanks for the info. I'll check out 3393-26!
            • 26modelB
              • Aug 2011
              • 28
              Hollywood,
              I happen to have a 26 single and this is one of the things my bike is missing. If you want to sell it, please let me know. Thanks, Mark H. 423sevenfourtwo2258
