panhead felts
  • p aiello
    • Mar 2003
    • 42
    panhead felts
    what's a good glue to use to glue the felts under the panhead covers when i took the covers off the felts where just laying on the rocker arm i got new felts
    • 5954
    The basic job of the felt is to absorb oil so there will be oil on the top end when a cold engine is started. I have pulled many apart to find the felts laying on top of the rockerblocks still doing the job they were there to do.
    • p aiello
      • Mar 2003
      • 42
      does it not also absorb noise?
        • Feb 2003
        • 5353
        Maybe a little bit but Chris' description pretty much covers it. It would be a pretty tall order to make a Pan top end completely quiet... I would just go to the auto parts store and find a good tube of sticky stuff that doesn't break down in oil. Zig zag it on the felts and let it set up. Then, coat them in oil for a headstart and slap them on! I've got some grey Permatex holding my felts on the valve covers.
        Cory Othen
        Membership#10953
        • Panacea
          • Dec 2011
          • 36
          Also make sure the holes line up with the rockers, just set the felts on top of the rockers with the glue applied, then set the covers in place. if they don't make contact, try again with some foam under the felts. Lift the covers off and make sure they're stuck...
          • larry
            • May 2009
            • 247
            Do the felts keep the oil on the inside of the rocker assembly, where it is needed?
            I once replaced the felts with foam (because I was smarter than Harley), and the foam fell apart, clogging the lubrication system.
              • 8236
              Larry!
              Felt reservoirs to supply oil for start-up after long periods of sitting was used by other marques prior to the H-D Panhead, such as for the intake rockers upon Indian Fours ('38-9 at least....)
              Noise was not an issue.
              • harleytoprock
                • Apr 2003
                • 374
                I've used contact cement to glue the felts with good results on panheads. I like when the felt is crushed between the cover and rocker bushings and studs. I believe the felts, on a panhead are to reduce the ringing that can occur with a sheet metal valve cover. Lubrication by felts is not a fast start up lube. It takes heat and time for the oil to weep out of the felt. The rockers on my Ace are aided with felt lubing because there is no oil feed to the rockers. The felt becomes the oil reservoir and the rider must add oil to the felts every so often..
                • larry
                  • May 2009
                  • 247
                  I, also, believe that the tight fit between the rocker assembly and the dishpan prevents the pan from resonating.
                  • kg993
                    • 263
                    I don't know if it was intended but I believe the felt also transfers some heat to the cover and gives a slight cooling effect.
                    Kerry
                    Kerry AMCA # 15911
                      • 4788
                      The aluminum covers also helped cut down on noise as they did not resonate like the SS ones. New placement chrome steel are noisy!
                      Robbie
                      • Panacea
                        • Dec 2011
                        • 36
                        I was thinking my new 64 is real quiet compared to the ridged pans I've owned, I'm sure the hydraulic lifters are mostly the reason but it does look to have aluminum covers too...Mike
