Thread: 58FL Dash Assembly...
    Default 58FL Dash Assembly...
    Hello All
    Does anyone have a picture showing how the gen/oil light lens is held in?
    I never had all the parts until now.... used a piece of tin can... hey it was the seventies....
    Had no money then....
    Thank you!
    3,108
    Steve, the lens goes in, the rubber slips over the metal tab (notch on tab to bottom) so the wide part of the rubber contacts the bottom of the lens, tab inserted between the raised fins, the shroud is bent down into the notch on the tab holding it all in place.
    Thank you Robbie
    Got everything installed and it looks awesome!
    Another task completed!✅
