58FL Dash Assembly...
  • Steve Galli
    • Nov 2019
    • 93
    Hello All
    Does anyone have a picture showing how the gen/oil light lens is held in?
    I never had all the parts until now.... used a piece of tin can... hey it was the seventies....
    Had no money then....
    Thank you!
    • 4790
    Steve, the lens goes in, the rubber slips over the metal tab (notch on tab to bottom) so the wide part of the rubber contacts the bottom of the lens, tab inserted between the raised fins, the shroud is bent down into the notch on the tab holding it all in place.
    • Steve Galli
      • Nov 2019
      • 93
      Thank you Robbie
      Got everything installed and it looks awesome!
      Another task completed!✅
