Results 1 to 3 of 3
Thread: 1937 transmission cover Jockey lid
  1. #1
    Apr 2009
    106
    Default 1937 transmission cover Jockey lid
    Does anyone have a picture of the transmission cover Jockey lid for 1937 . I am trying to figure out the hole for the shift cam that was drilled all the way through . What size was the hole. Thanks in advance.
  2. #2
    Jul 2012
    Inman, South Carolina
    82
    3/8" diameter
  3. #3
    Sep 2016
    Oregon
    156
    37 jockey lids were blind drilled, which makes them a bitch to remove the shift cam's shaft. many of them have been drilled 1/8"- 3/16" to match the later lids so you can use a punch to remove the shaft. i'v had to do that on a few lids.
