1937 transmission cover Jockey lid
  • DANPATCH
    • Apr 2009
    • 313
    Does anyone have a picture of the transmission cover Jockey lid for 1937 . I am trying to figure out the hole for the shift cam that was drilled all the way through . What size was the hole. Thanks in advance.
  • RCamp
    • Jul 2012
    • 99
    3/8" diameter
    • knucklehead 61
      • Sep 2016
      • 353
      37 jockey lids were blind drilled, which makes them a bitch to remove the shift cam's shaft. many of them have been drilled 1/8"- 3/16" to match the later lids so you can use a punch to remove the shaft. i'v had to do that on a few lids.
