Results 1 to 7 of 7
Thread: Vintage Light Bulb Availability
    Feb 2011
    101
    Default Vintage Light Bulb Availability
    Does anybody know if "old style" dual-filament light bulbs are still made? These were used in tail/brake light applications.
    The base style is like a modern "1156 single-element" bulb in that both of these have the 2 alignment pins evenly spaced near the bottom.
    Modern "1157 dual-filament" bulbs have the alignment tabs off-set on each side. Any help would be appreciated.
    Thank you.
    Dec 2001
    529
    Vintage Ford in Sacramento has them. You can buy them online off their website. Rich
    DrSprocket
    Another option:
    www.RestorationStuff.com
    Nov 2018
    Reno NV
    334
    Quote Originally Posted by motor-officer View Post
    Thank you.
    The bulbs you want have a designation of "BA15D" base. Twin filament of the wattage you want. These are the bulbs with the pins aligned. Available most places, and as LED's.
    The bulb number is 1158. Plenty of sources out there. I look for old American made ones on ebay. One good old brand is Tung-Sol.
    Dave
    Jul 2017
    NW Ct.
    111
    Halogen replacements (much brighter, similar draw) are also available. I got them from LBCarCo.com Hope this helps. Smitty
    1,431
    I've also got some compact stop/tail lamps with straight pins which fit under the early Harley flat glass lens if retrofitting pre-1935 bikes with a stop light. Part number on the box is 770385. I also bought a hundred nos single filament T63 straight pin taillight bulbs years ago from Dixie and still have about half left for originality fans.
