Vintage Light Bulb Availability
  • motor-officer
    • Feb 2011
    • 199
    Does anybody know if "old style" dual-filament light bulbs are still made? These were used in tail/brake light applications.
    The base style is like a modern "1156 single-element" bulb in that both of these have the 2 alignment pins evenly spaced near the bottom.
    Modern "1157 dual-filament" bulbs have the alignment tabs off-set on each side. Any help would be appreciated.
    Thank you.
  • RichO
    • Dec 2001
    • 903
    Vintage Ford in Sacramento has them. You can buy them online off their website. Rich
    DrSprocket
    • PaulCDF
      • Aug 2019
      • 1422
      Another option:
      Supplying period correct restoration products & accessories to the pre-war vehicle & marine enthusiast for 25 years!
      • aumick10
        • Nov 2018
        • 465
        Thank you.
        The bulbs you want have a designation of "BA15D" base. Twin filament of the wattage you want. These are the bulbs with the pins aligned. Available most places, and as LED's.
        • ammorest
          • Sep 2008
          • 301
          The bulb number is 1158. Plenty of sources out there. I look for old American made ones on ebay. One good old brand is Tung-Sol.
          Dave
          • HDSmitty
            • Jul 2017
            • 282
            Halogen replacements (much brighter, similar draw) are also available. I got them from LBCarCo.com Hope this helps. Smitty
              I've also got some compact stop/tail lamps with straight pins which fit under the early Harley flat glass lens if retrofitting pre-1935 bikes with a stop light. Part number on the box is 770385. I also bought a hundred nos single filament T63 straight pin taillight bulbs years ago from Dixie and still have about half left for originality fans.
