Results 1 to 5 of 5
Thread: Help identify this tail light housing
  1. #1
    Jan 2015
    Calgary Alberta
    14
    Default Help identify this tail light housing
    I bet someone out there can tell me what this taillight assembly is off.
    IMG_20200321_100426.jpgIMG_20200321_100441.jpgIMG_20200321_100450.jpgIMG_20200321_100506.jpgIMG_20200321_100525.jpg
  2. #2
    Sep 2005
    Sarasota, Florida
    4,251
    The bucket looks like a proprietary item used on trailers and trucks. If you take that off, there might be "Harley-Davidson" stamped in the metal. Unfortunately, someone would have drilled through the stamping to mount that cheesy bucket. But, people did what they had to do to keep things rolling along.
    Jan 2015
    Calgary Alberta
    14
    Quote Originally Posted by exeric View Post
    Thanks Eric. I will take a look and see if there is any stamp.
    Pat
  4. #4
    Jan 2015
    Calgary Alberta
    14
    Great job Eric. You nailed it. Its Harley. See photo now that the lens holder is off.
    Thanks again.
  5. #5
    Sep 2005
    Sarasota, Florida
    4,251
    That is savable with a carefully made steel plug of the right diameter. Ballpeen the plug tight, judicious filing, and Bob's your uncle. I've seen reproduction buckets, so good find, Pat.
