Help identify this tail light housing
  • cdnradio
    • Jan 2015
    • 30
    I bet someone out there can tell me what this taillight assembly is off.
    IMG_20200321_100426.jpgIMG_20200321_100441.jpgIMG_20200321_100450.jpgIMG_20200321_100506.jpgIMG_20200321_100525.jpg
    • 5999
    The bucket looks like a proprietary item used on trailers and trucks. If you take that off, there might be "Harley-Davidson" stamped in the metal. Unfortunately, someone would have drilled through the stamping to mount that cheesy bucket. But, people did what they had to do to keep things rolling along.
    • cdnradio
      • Jan 2015
      • 30
      Thanks Eric. I will take a look and see if there is any stamp.
      Pat
      • cdnradio
        • Jan 2015
        • 30
        Great job Eric. You nailed it. Its Harley. See photo now that the lens holder is off.
        Thanks again.
          • 5999
          That is savable with a carefully made steel plug of the right diameter. Ballpeen the plug tight, judicious filing, and Bob's your uncle. I've seen reproduction buckets, so good find, Pat.
