Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 1937 ULH low Cylinder Pressure
    Sep 2009
    Alaska
    151
    Default 1937 ULH low Cylinder Pressure
    Ok guys, here we go again. I went and bought new cylinders from CycleFab, with fitted pistons and valves. I had my head surfaces checked on a friends CNC Mill, they were warped, it took .020" to get them flat. Put her together and it felt like no compression when I kicked her. I put a quality compression gauge and 22 PSI. I squirted a little Corrosion X in and 26 PSI.Double checked the valve clearances and perfect. Now, with milled heads and new cylinders with fitted pistons, my PSI should be up there a little more. Only answer would be a HUGE ring gap, or possibly the cylinder decks didn't get machined enough? She's on the lift begging to get tore down, but I may be missing the obvious????
    Steve
    Sep 2009
    Alaska
    151
    Oh, annealed copper head gaskets.
    Steve
    3,074
    Throttle wide open for the test?
    Sep 2009
    Alaska
    151
    Yes, wide open
    Steve
    3,074
    Clutch not slipping?
    Oct 2011
    580
    Any chance the cam timing is off?
    Jul 2017
    NW Ct.
    107
    Rings on upside down? Valves seating properly?
    Sep 2009
    Alaska
    151
    I'm checking all of that today, Thanks
    Steve
    Sep 2009
    Alaska
    151
    So I just heard that some of Cyclefabs ULH guides aren't concentric with the seats. Really? Holy Sh*t! I heard this guy was great. Ok, leak down test this weekend! Everything else checks out. Lifter clearances, clutch fully engaged. I took my OEM cylinders off after starting her because it was .060" over and the valve seats were so deep that I had to make special 7/16" wrenches to fit down in the lifter blocks to adjust them.
    Steve
    Nov 2008
    Virginia
    538
    I would be careful here as Paul uses Kibbelwhite valves and guides for those. May not be a problem from him but them. He has them made up specifically for him and to his specs. so would think that if there is a problem it would be with all of them. I know several folks who have his cylinders and that was never a problem for them. Might have had other small issue but not that. I have had him do several motors for me over the years and while I can't recommend him right now due to delays in getting work out I would say he has spent more time and money figuring out HD flat head than anyone I know. I am sure if you find he is at fault he will make it right. Good luck!
    Tom (Rollo) Hardy
    AMCA #12766
