Results 1 to 10 of 10
Thread: Point gap variance
    Feb 2019
    11
    Default Point gap variance
    Iíve set my points on my JD to .022 in the advanced position when I retard the distributor the gap goes out to .035. I realized the breaker plate has some wear at the pivot point on the dist body and thatís where the variance comes from. Iíve been told by another JD owner that he leaves his dist in the advance position all the time and it doesnít matter. I know if I donít retard the spark on my 48 Pan Iím likely to have a broken leg. Should I have any concerns about this on the JD ? I havenít started the newly rebuilt engine yet but Iím getting close.
    Menomonie, WI
    1,364
    My 25 JD always likes to be retarded a little when I start it. Some people don't do it - luckily they do not seem to kick back as hard as a panhead.
    Jerry
    Quote Originally Posted by Mike Dix View Post
    I’ve set my points on my JD to .022 in the advanced position when I retard the distributor the gap goes out to .035. I realized the breaker plate has some wear at the pivot point on the dist body and that’s where the variance comes from. I’ve been told by another JD owner that he leaves his dist in the advance position all the time and it doesn’t matter. I know if I don’t retard the spark on my 48 Pan I’m likely to have a broken leg. Should I have any concerns about this on the JD ? I haven’t started the newly rebuilt engine yet but I’m getting close.
    Nov 2018
    Reno NV
    323
    Mike, if you have gone to the trouble of rebuilding the engine, i would suggest you go the extra mile and rebuild the generator/distributor/timer.
    What year are you rebuilding?
    May 2005
    NH
    459
    I had this exact problem. I was able to open up the points plate and made a bushing to press/loctite in. I retard my timing frequently.
    Dan Margolien
    Yankee Chapter National Meet July 31/August 1 2020 at the TERRYVILLE Fairgounds, Terryville CT.
    Www.yankeechapter.org
    Pocketvalve@gmail.com
    963
    3,074
    If you are actually riding your bike as it was meant to be operated you will be using the advance grip alongside the throttle for best performance. Steep inclines, long grades, slow traffic, all benefit from use of both controls. Fix yours.
    Feb 2019
    11
    Rebuilding a “29”
    Feb 2019
    11
    Was thinking along that line. Checked the dist housing and that has wear. Looks like it could be brazed and it’s easy to chuck up in the lathe. Thanks for the input
    963
    Couldn't agree more with Robbie's sage advice. not being able to roll on the retard in city 90 sharp street turns or in traffic, or loose gravel, the bike can definitely move faster than is comfortable. using retard/advance makes for overall smooth operation.
    Another thing to check is the breaker arm pivot bushing. This 1919 I'm working on ran like dookie until I made a new bushing.
