Point gap variance
  • Mike Dix
    • Feb 2019
    • 13
    Point gap variance
    I’ve set my points on my JD to .022 in the advanced position when I retard the distributor the gap goes out to .035. I realized the breaker plate has some wear at the pivot point on the dist body and that’s where the variance comes from. I’ve been told by another JD owner that he leaves his dist in the advance position all the time and it doesn’t matter. I know if I don’t retard the spark on my 48 Pan I’m likely to have a broken leg. Should I have any concerns about this on the JD ? I haven’t started the newly rebuilt engine yet but I’m getting close.
    • 2016
    My 25 JD always likes to be retarded a little when I start it. Some people don't do it - luckily they do not seem to kick back as hard as a panhead.
    Jerry
    • aumick10
      • Nov 2018
      • 465
      Mike, if you have gone to the trouble of rebuilding the engine, i would suggest you go the extra mile and rebuild the generator/distributor/timer.
      What year are you rebuilding?
      • DanM
        • May 2005
        • 465
        I had this exact problem. I was able to open up the points plate and made a bushing to press/loctite in. I retard my timing frequently.
        Dan Margolien
        Www.yankeechapter.org
        Pocketvalve@gmail.com
        • Steve Swan
          Possessed by Motorcycles
          • Aug 2013
          • 1589
          from full retard, to start i advance i turn the grip about 1/3 towards advance.
          Steve Swan
          27JD 11090 Restored
          27JD 13514 aka "Frank"
            • 4777
            If you are actually riding your bike as it was meant to be operated you will be using the advance grip alongside the throttle for best performance. Steep inclines, long grades, slow traffic, all benefit from use of both controls. Fix yours.
            • Mike Dix
              • Feb 2019
              • 13
              Rebuilding a “29”
              • Mike Dix
                • Feb 2019
                • 13
                Was thinking along that line. Checked the dist housing and that has wear. Looks like it could be brazed and it’s easy to chuck up in the lathe. Thanks for the input
                • Steve Swan
                  • Aug 2013
                  • 1589
                  Couldn't agree more with Robbie's sage advice. not being able to roll on the retard in city 90 sharp street turns or in traffic, or loose gravel, the bike can definitely move faster than is comfortable. using retard/advance makes for overall smooth operation.
                  Steve Swan
                  27JD 11090 Restored
                  • scooterwrench
                    • Mar 2020
                    • 19
                    Another thing to check is the breaker arm pivot bushing. This 1919 I'm working on ran like dookie until I made a new bushing.
