Tech Info For 1925 Scout
  • Gob-Iron Simo
    • Oct 2009
    • 1
    I was hoping somebody may know the following:
    clearance for piston to bore? using ali pistons
    ring gaps?
    valve to guide clearance?
    crank end float?
  • Tom Lovejoy
    • Aug 2006
    • 951
    I might be able to git you some info if needed, but not without checking. I dont want to give ya no wrong info. I can tell one thing right off, if your looking for head gaskit's. I know of only one source, lot's of people think they have em. But their all or most all wrong, I got a stack of em - all wrong. Found out 25 was a one year only, little changes in 26 and on. Moen has them and their perfect, you can git em on the Virtual Indian site. Might be the same thing for the 25 Prince I would think. Do you have a 25? I just got my running right, hope to take it out tomorrow. Good luck with your's.
    • Tom Lovejoy
      • Aug 2006
      • 951
      I would post your question in the engine trans rebuilding section, probably git alot more responces, hopefully. I was going to give ya the info out of my books and well if needed. But theres lots of experienced guys on here so hopefully they well give you their thoughs, good luck.
