1928 scout oiling system
  • Chris56
    • Apr 2009
    • 5
    Hi
    I need help with oiling system on my 1928 101 Indian Scout
    Just been rebuilt- new pistons with oil control rings from Hecker 101 in Germany
    on this model the crank case vent is on the clutch case side. It leaks a lot of oil at lower engine speeds, why did Indian move it to the timing cover later?
    Any ideas what is the problem? and how to fix it!
    Regards
    Chris
  • Ken Lee
    • Aug 2001
    • 298
    Hello Chris , I think one problem is these bikes weren't designed to run with oil control rings and maybe they give more pressure in the crank case , check the crankcase level plug to see if too much oil is getting in te case and if so cut the oil down a bit but do this a little at a time as too much is better than too little ! Are you a member of the 101 association ? you could ask on their site too , best of luck , Ken
    Ken
    • jimmyallison
      • 22
      How does one find about the 101 Association?
        • 5950
        • Indiantim
          • Mar 2011
          • 61
          Hi
          I had exactly the same problem on my 101 with the same pistons, first I relocated the breather to the timing side as per an Indian service shot. Still the crankcase filled with oil and the motor overheated. Even caught fire on one occasion!
          Next I removed the oil rings, problem solved! adjusted oil pump to 150 miles per quart, as recommended by the guru George Yarioki. Oil pump adjusting screw is wound quite a way in! The motor should burn oil like a 2 stroke, slight haze when warm. After standing for some time drain the crankcase.
          I have done about 5000 miles since I removed the rings with no problems.
          Hope this helps
          Regards
          Tim
          '36 four. '44 Chief & sidecar. '28 Scout. '67 XLCH. '70 BSA. and a Guzzi...............
          • indianut
            • Feb 2005
            • 308
            Absolutely, you can not use oil rings on a Total Loss System! For Street use. On the other hand, when I am setting up a Wall Bike I put oil rings on it, but I do not use an oil pump, or even plumb the oil lines. Every few days of use I drain the case and put a couple of ounces of fresh oil back in!
            http://laughingindian.com/
            A.M.C.A. Member Since 1986
