On a 45" SS-640. Rear eng. mnt. plate -left side. A spacer is located middle of eng. plate. This spacer (IND PN 39887) is 3/4 OD,3/8ID, approx.1 1/4 L, . My question: in the parts book this spacer appears to have a step on it. Is this correct? If so, what are the dimentions of the step?
Is the step there to hold an additional lock washer for this spacer? Is this spacer used to help support the primary back? with a 1/4" bolt that is inserted from the open primary side, then bolting to the eng. plate? help....
Would the step then fit into the primary back? help....&$*%#&$@#%$@ spacers.
**I sure could use the dimentions of the spring plate for side stand PN 43123. Holds side stand spring top.
