1934-1940 Horn
  • #31
    JR,
    The military 640B was basically a Sport Scout with a few changes.
    The horn on the 640B mounted to the fork body ( not the handlebars) just like the Sport Scout.
    The 741 horn mounts to the frame under the gas tank. The 741 fork body is different than Sport Scout. It’s about an inch longer, and up top there is no mounts for the horn. I think the reason for that is the 741 speedometer mounts to the fork body (640B speedo in the dash), and if the horn is mounted to the fork body it would block the rider’s view of the speedo.
    Its hard to get the above photo cause you’d need 3 hands but you get the idea.
    I guess you could come up with some sort of clamps on the handlebars, but the center cast portion of the bars is pretty wide compared to the spacing of the studs on the horn so I don’t know how that’ll look.
    • #32
      Well, the reason I asked is because I plan to mount the '34-'40 horn on the civilian 741 and thought I could use something like the two brackets that are curved from the 741 horn set-up. These are actually also shown in the 1940 chief parts manual.
      They just seemed to be more ergonomic mated to the handlebars because the curve in them seems more shaped to the handlebar diameter, but I've never tried to fit them because everything is just parts right now in this early phase.
      Then, I have recently acquired the 340 and '34 Chief parts books to see if there were other brackets that would work. I didn't know much about the J shaped brackets used on the 340-B.
      They look like they are not open enough to fit around the bars. I also noticed in the parts book, there are two back shields (horn covers); one is a half and one a whole.
      there seem to be more pictures in the later parts list manuals and I noticed the 1940 shows the half shield for that year. Other books, like Bogaert's, An American in Paris, shows many photos of actual military chiefs with full back covers on them.
      Thank you for the photos and help.
      -JR
      • #33
        Hey JR,
        Let’s look at some of this. What you are calling the “J” bracket is, I think, the Chief horn bracket:
        From Greers website.
        Here they are mounted on a Chief fork…
        They were used on 38 to 45 Chiefs and 38 to 42 Fours. They are meant to mount to the fork body, not around the handlebars.
        Here they are compared to Sport Scout mounts…
        The four bigger holes mount to the horn body, the lower holes mount to the forks.
        Here is an up to 1940 Chief setup…
        Along the studs on the back of the Indian face horn there is a rubber pad, then a metal cup with projections that fit inside the big holes on the mounting bracket, then another rubber pad and another metal cup, but this cup has clearance holes for the 10-32 threaded end of the stud but smaller then the 1/4” stud body. The back cover is then put on with acorn nuts. This essentially captures the horn bracket between the rubber pads, allowing the horn to vibrate, the horn is “floating” on those rubber pads.
        The setup is the same for the Sport Scout except for the shape of the mounting brackets.
        • #34
          You mentioned about the two different style back covers, that has to do with the change in horn design from 1940 to 1941. On the later horn the 4 studs were replaced with a rectangular plate that has threaded holes the same spacing as the studs. On these horns the back cover was replaced with a single screw to a threaded hole in the center of the horn body…
          Here it is set up for a Scout. The back wasn’t flat because it didn’t need the 4 acorn nuts, it was rounded, which looked better with the stream lined fenders (?).
          Compare to the earlier horn….
          So I think where you are a little mixed up is you are looking at two different horn bodies and their corresponding back covers, and different brackets for the Chief and Scout.
          Hope that clears some of it up.
          Joe
          • #35
            Yes, that clears things up. But I only need the parts you show above. I have all the parts for the 741 rounded back and brackets, except one of the long ones is broken.
            I'm still puzzled as to how to figure out the handlebar mounting, like you said. That part will be a custom make if it is even possible.
            Thanks.
            -JR
            • #36
              JR,
              Yes, for your “chevron” or 1941 - 1945 horn you have the correct face and horn body, but what you call the “long” brackets are not right for the 741 (they are for Sport Scout or 640B). You need the bracket shown in the Jerry Greer diagram that mounts it on the frame under the gas tank…
              I highlighted the parts you will need to mount it to your 741.
              Also, I wanted to correct something I stated earlier, what you were calling the “J” brackets mount the horn on a Chief not to the fork body but rather through the handlebar casting as shown in the Jerry Greer diagram below…
              • #37
                JR,
                You said you found an Indian face horn but I had said push come to shove you could find a car horn and convert it. I decided to try just that. Started with a painted and rusty car horn lacking the studs on back for the Indian mounting. I forgot to take a before picture but here it is cleaned up…
                I then used a drill guide I 3d printed to get the holes in the right position…
                I made these pilot holes then used the tap drill…
                I tapped the 10-32 holes, cut some round head screws to the correct length and screwed them out from the inside and put a jam nut on the outside…
                I got some tubing the right size and made some sleeves up to the correct length to mimic the studs on the original horn…
                Now I just have to modify a couple of the rubber cushions and I’ll be good to go.
                • #38
                  And just an FYI the studs on the original horn are peened over on the inside like rivets
                  There is not much clearance inside but round head screws did work, and I would guess socket head would also fit…
                  • #39
                    Joe, I have a couple of those horns lying around and have often thought about doing what you did but just never found the time. Unfortunatly I don't have an original horn or a 3D printer to make the template for the drill guide. Any suggestions? Any way Joe, nice work as usual.
                    Dave
                    • #40
                      I was told this was horn mounting plate (Probably should have cleaned it better before putting down on paper)
                      Graph paper is 4 squares per Inch.
                      • #41
                        Joe,
                        That's a great lesson on how to make a correct period horn work on a bike.
                        I asked about the brackets because I am not going to mount the horn on the side. That's why I said I will most likely have to do something custom or ask around to see what other people have done in trying to mount a horn to the center left handlebar. I would also like to see it above the motolamp, which might be a difficult thing to do and may not work at all.
                        -JR
                        • #42
                          JR,
                          Well good luck with your custom mount, let us know how it turns out.
                          Paul,
                          Seethe below pictures of the bracket on the 1941-45 horn body. Looks to be the same size what you got.
                          I guess someone cut it off the back of a bad horn? The threaded holes should be 1/4-28. Don’t know how you’d reuse that.
                          Dave,
                          I’m going to be redoing the drill guide, maybe this week. I’ll print you out one (for free). I’ll message you when done for your address.
                          Joe
                          • #43
                            Just an FYI here is my converted horn back…
                            That’s an original face on there, I gotta drill and tap a repop face to complete the horn.
                            • #44
                              Joe that would be GREAT Thanks Much!
                              • #45
                                Thanks, Joe. The horn looks awesome.
                                I will let you know what I am able to figure out as soon as I get forks made up to test different options.
                                -JR
