adjusting cone finish
  • adjusting cone finish
    would someone know the correct finish for the adjusting cone on the fork of a 29 101?, i do know the cone nut is nickel, thanks
    I believe it is also nickel plated as well. So, your plater will need to mask off the bearing surface before plating.
      I vote for nickel too….
      Pretty sure this one’s original and it looks like nickel to me….
        nickel it is..........thanks for the help
          ...the R&O says bright nickel for '28 & '29, chrome for '30 & '31
