1922 Scout wheels
  • jimpauls
    1922 Scout wheels
    I am building a 22 scout and need wheels perferbaly with spokes and hubs,and also tires.Not much information on what sizes to use.Can use all the help I can get.Thanks.
    Hey Jim,
    There's a set of Scout wheels on ebay right now. The item # is 180056039744 They might be later twenties wheels, but it might be worth a look. Have you contacted any of the Indian gurus in Ontario? I know of one or two in the Kingston area............
    • jimpauls
      Thank you for the fast reply CO.I would like to contact the guys in the Kingston area also.
        I asked around about wheels for your Scout and came up with zip. I'll still keep an eye open for you though...........maybe someone else can help out Jim????
        • 20scout
          Jim,
          What side is the brake and sporket on? What size rim are you looking for?
          Regards,
          TR
          • jimpauls
            Hi,TR ,as much as I know an old parts book refers to tires as 26x3 which should make the rims 20?I have a set of 28x3 with tires and tubes,but they are not going to fit,the hub on the front wheel is too wide.Thanks,Jim.
            • 20scout
              Hi Jim,
              26x3 is standard for tires on the early scouts and new ones are available. I checked my goodie pile and have a set but they are for later scout. But I do have an original 20' scout if you need referance photos and information. Contact me off-list at dexters@rea-alp.com
