741 Scout flywheel timing marks
  • 741 Scout flywheel timing marks
    I was trying to static time my 741 motor. I could not find any marks on the flywheel through the timing hole. All I found were 2 drilled holes in the flywheel. Are those for balancing, or are they for timing?.
    I looked at my741 wheels and they have a + and 0 marks.Looks like the + is tdc and 0 with a line thru it is full advance .Marks are not deeep.
      Thanks Tom. I see them now. You're right, they're not very deep. Thanks for the reply. Dave. And why does it keep saying I'm a new member?. I have been a member since 1986.
        It says you are a new member to the forum, and will do so until you exceed a certain number of posts.
          Did not know that, Thanks.
