Ammeter 1941 Sport Scout
  • lux
    • Aug 2017
    • 35
    I lost the bezel and glass from my ammeter on the road some where.
    I got the old one out of the dash to try and just size it up for replacing the glass and bezel. I found that it is a plastic and very cheep looking ammeter.
    Should I just replace the whole thing with something else?
    If so what should I look for?
    I hate to put it back in to find out later I'd be better off with something better.
    Thank You
    • 6002
    Jerry Greer has a correct reproduction of the '41 SS ammeter. If you don't care about that, I would measure the hole in your instrument cover and look for one on ebay that is the right diameter, voltage, and amp range.
    • lux
      • Aug 2017
      • 35
      Thanks for the reply. I'm not 100% sure but I think the original for a 41 SS is the Hoyt ammeter.
      I found one of those for $99.
        • 962
        Resto guide shows the Hoyt.
        • lux
          • Aug 2017
          • 35
          Thanks Tom,
          Can you tell me what "Resto Guide" you are useing? I need to get one of those.
            • 962
            Indian motorcycle Restoration guide 32-53 by jerry Hatfield.
            The pics of ammeters andyear listings are little confusing and some things in t hebokare not always correct.Same forJerry Greers Indian listings.
            • lux
              • Aug 2017
              • 35
              Sounds better than what I have now. I'll do a search for it thank you.
                • 1667
                The pics of ammeters and year listings are little confusing and some things in the book are not always correct. Same for Jerry Greers Indian listings.
                Right! Greer's has the Conn. Tel. ammeter listed for 1941!
                • lux
                  • Aug 2017
                  • 35
                  Thanks Tom and Harry,
                  Are you guys in agreement that the Hoyt is correct for 1941 Sport Scout?
                    • 6002
                    Hoyt is correct for 1941.
                      • 1667
                      Yes, I'd go with Hoyt, agree with Tom and Eric on this. You know Greer's is pretty darn good, but I trust Hatfield's research more (even though I have a document with 8 pages of corrections to the Restoration Guide, first edition, but the ammeter for '41 was listed as Hoyt in the Guide and not corrected!)
                        • 962
                        Interesting that the Resto Guide pic says 41-through early 46.
                        A just listed as 41 Hoyt on ebay shows basically the same gauge however the ebay listing has 2 rivets above the Indian script,whlie the pic in the resto guide shows 2 screws lower before and after the script on the center line thru the script.
                        Were there actually two versions of the 41 gauge?Generally I thought screws to hold the face were an indication of a repalced face or repro gauge.
                        I think the ebay listing looks more original the the resto guide pic but I dont know.
                          • 6002
                          I have a genuine Hoyt ammeter from a '41 dash assy. The face is riveted as Tom described in the above post.
