1940 sport scout leaks from primary chain adj screw
  • kunzog
    AMCA #710
    • Dec 2001
    • 154
    After sitting for years, I am getting my 1940 Sport Scout ready to ride. After filling the primary drive with 30 weight oil, I notice that it is leaking from the primary chain adjusting screw at the bottom of the primary cover. Should there be some sort of gasket or sealant there? Not a lot of oil but a small amount over several days.
  • tomfiii
    • Jun 2007
    • 316
    Look hear at Pressure-Rated Metal-Bonded Sealing Washers for Nuts and Washers
    McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
    • kunzog
      AMCA #710
      • Dec 2001
      • 154
      thanks for the response, I was hoping someone could tell me the factory way of sealing this bolt and nut
        • 971
        I believe they just used some gasket sealer.
        I either make a paper washer gasket with id small enough that it sort of threads on the screw,or a few wraps of Teflon tape.
        • kunzog
          AMCA #710
          • Dec 2001
          • 154
          That's the information I am looking for, Thanks
