45" Scout 101 Manifold ID
  • Henderson31
    • Jan 2014
    • 10
    In need of an intake manifold for a 45" 1928 Scout. Can anyone tell me how to identify the correct manifold?
  • Tom Lovejoy
    • Aug 2006
    • 951
    I would post the same thing on the 101 web site, should git a quick reply I would think. Hopefully someone here will chime in.
    • Tom Lovejoy
      • Aug 2006
      • 951
      a couple photos
      1-11-2014 9-33-06 AM_0001.jpg1-12-2014 8-26-56 AM_0003.jpg first ones is off a 37 cu inch, second is 45 101 that I was ridding with today. They should be a t manifold not a y, hope that helps abit.
      • Henderson31
        • Jan 2014
        • 10
        Originally posted by Tom Lovejoy View Post
        [ATTACH=CONFIG]12475[/ATTACH][ATTACH=CONFIG]12476[/ATTACH] first ones is off a 37 cu inch, second is 45 101 that I was ridding with today. They should be a t manifold not a y, hope that helps abit.
        Thanks Tom! The photo's should help.
        • gsottl
          • 216
          you need to be very careful to find a manifold with the right intake diameter - 741 manifolds look nearly the same when you find them on a swapmeet, but the thread Diameter on the 101 45ci is slightly bigger. Unfortunately I do not have one on hand right now an do not know the thread size by heart, but your cylínder shound tell you what is right.....
