Need cylinders
  • Need cylinders
    My 29 101 basket case is proving to be quite a project. I need a pair of usable cylinders. Any help is much appreciated.
    jimmy
    Take a look on Vintage Cycle Bay if you can't find anywhere else. They seem to have some stuff altho I haven't personaly used them
      Those cylinders will be pretty hard to find. You Could, if you need to, use ANY Indian Scout Cylinders on your 101.
      http://laughingindian.com/
      A.M.C.A. Member Since 1986
        I appreciate both suggestions. Thanks.
          I believe I have seen those cylinders come up on E bay a couple times. I think their out there, trying to find a good set might be a bigger deal, maybe sleeve em? My 25's have been sleeved, wish ya lot's of luck with it and the Cannonbal. Also I believe they are making new ones now - think there from down under?
            Check out Indian Parts Europe. They seem to be building quite an array of 101 parts. Maybe they can hook you up with a pair of jugs:
            http://indianpartseurope.com/index.html
              Someone in Australia was making some nice ones, but I cant remeber the details, Try Parker Indian?
              Steve
                Jurgen Hecker trading as Hecker 101 was offering them, they originate from the Czech republic! However I cannot recommend him as it took almost a year to supply them. The quality was good with no alterations needed to fit them.
                Try Reno Indian dot com
                Regards
                Tim
                '36 four. '44 Chief & sidecar. '28 Scout. '67 XLCH. '70 BSA. and a Guzzi...............
                  Has anybody had any dealings with seller JDJIMN at vintagecyclebay.com ? He's out of Lake Elsinore, CA.
                    Is the link below reliable?
                    http://www.enfieldracing.com/indian_scout_17.html
                    • #11
                      I visited with this guy at the Vintage Event at Barber Motorsports in Oct. He seemed to be a good guy to me.
                      • #12
                        Originally posted by JohnR View Post
                        My post above was refering to this guy. Sorry.
                        • #13
                          101 cylinders
                          IMG_0247.jpgIMG_0248.jpgI have 3 sets of 101 cylinders that I do not need personally and can swap/sell - Would swap against Chiefs cylinders 1932-39 - any version or sell.
                          Set 1 front Min. 73,90 / Max.74,21 pitted (new bore app.75,00) rear Min. 73,90 / Max.73,95 (good)
                          Set 2 front Min. 74,04 / Max.74,58 pitted (new bore app.75,00) rear Min. 74,45 / Max.74,95
                          Set 3 front Min. 74,02 / Max.74,22 (scores) rear Min. 74,10 / Max.74,60 (scores)
                          mesurements in MM
                          I have put them as pairs, but can also swap/sell them in another arrangement.
                          Please contact me by PM with email-address for detailed pictures.
                          Greetings,
                          gsottl
                          AMCA # 15841
