warrior pistons
  • portagepan
    • Feb 2006
    • 580
    warrior pistons
    A friend of mine has had trouble finding pistons for his Warrior. He called Wiseco, and I guess they will make them for a price. Is there a place to get Warrior pistons, or anyone else who can make them? Thanks.
    Mike
  • Tom Lovejoy
    • Aug 2006
    • 951
    I would check with Bob Stark, I would be surprised if he does not have em. Having them made up is not a big deal either, but I would try Bob. Good luck.
    • rigb
      • Jun 2009
      • 143
      Rittman Cycle in Ohio has what was once Jim Sutters Vertical stuff. Southwest Vintage in New Mexico advertises having a lot of Vertical stuff. Bob Markey used to have a lot of vertical stuff, I got the last N.O.S. standard bore set when he and Robin rebuilt my 249 engine around 1988, but the Warrior bore is I think +10.Glenn Ableman in Albany N.Y. has some Vertical stuff, I've sent a few guys his way. I have his info if you need it. Anything I might have is used. Hope this helps. Brian.
