Vertical Twin Ignition
  • brian_groff
    Does anybody have a recommended parts list for upgrading the ignition on Indian vertical twins?
    -Regulator
    -Dual-fire coil
    -Points & condenser
  • Kojack
    http://www.oregonvintage.com/threads.html lists a bunch of interchange numbers. I'm not sure about the points but the condensor and regulator listed for other Indians should work fine. People usually replace points because they are so cheap but I've never really seen a set worn out. They can usually get by with a filing and gap set. Check out the Thunderbolt 6V coil shown at: http://www.legendmcs.com/Electrical-Ignition/coils.html
    That's the type I use on mine. Nice and compact.
    • brian_groff
      Thanks for the tip.
      Poking around, I happened across that Thunderbolt coil from Legends and picked one up. Good to know it works fine.
