Voltage Regulator
  • jim wagnon
    • Dec 2021
    • 137
    Voltage Regulator
    Hello all, asking for any advice on sourcing a solid state voltage regulator 6v negative ground I can hide inside an Indian vertical voltage regulator. The one I found requires the field coils in the generator to be rewired. I’d rather not do that.
  • PaulCDF
    • Aug 2019
    • 1435
    Jim
    Just a suggestion contacting: IndianFrank@yahoo.com
    I do not know him personally but have read good things.
    • jim wagnon
      • Dec 2021
      • 137
      Hi Paul, email sent. Thanks for the tip!
      • PRG
        • Nov 2006
        • 617
        Howdy sir,
        If your generator is in stock three brush configuration you’ll have to convert it to two brush. Not difficult, a search on this forum will provide instructions. Many years ago I adapted Bob Kizer’s superb PODtronics regulator to work on an Autolite. All my Indians have, and others, run on these without fail for years. He’s since retired and his business sold to Coventry Spares at the link below. Fuse at 15amps on the positive side, no HD circuit breakers on the ground strap.
        http://www.patwilliamsracing.com/194...ianchief35.jpg
        Cheerio,
        Peter
        #6510
        • jim wagnon
          • Dec 2021
          • 137
          Thanks Peter!
          • Skirted
            • Sep 2012
            • 709
            Jim,
            Did you get the solid state regulator sorted out yet?
            Jason Zerbini
            #21594
            • jim wagnon
              • Dec 2021
              • 137
              Originally posted by Skirted View Post
              Jim,
              Hi Jason, I actually found a couple NOS regulators that might work. I’m having my core regulator cad plated and we’ll decide what direction to go down the road.
                I see this is an old thread, but...
                Originally posted by PaulCDF View Post
                Jim
                I shall personally vouch for IndianFrank@yahoo.com
                I owe him.
                • Skirted
                  • Sep 2012
                  • 709
                  The Vertical generators are 2 brush which eliminates need for 3 to 2 brush conversion of gen. A few years ago I converted one of my 249 Scouts to electronic and run a Shorai battery so if you decide to go that route, shoot me a PM. But yea, typically owners of these bikes don't ride them much and if that will be the case if you can get a mechanical regulator to work it might be best route.
                  Are you still running the magneto for the ignition?
                  Jason Zerbini
                  #21594
                  • jim wagnon
                    • Dec 2021
                    • 137
                    Hi Jason, I am running the magneto. I’ll ride it a fair bit and would like to have a good charging system. Ideally if the regulator I found won’t work I’ll go electronic.
                    • jim wagnon
                      • Dec 2021
                      • 137
                      I owe him.
                      Hi Cotten, corresponded with Frank today. I’ll be sending my regulators off to him Wednesday. Thanks much!
                      • jim wagnon
                        • Dec 2021
                        • 137
                        Jim
                        Thank you Paul for your recommendation.
                        • jim wagnon
                          • Dec 2021
                          • 137
                          Indian Frank is a pleasure to work with. My regulators are gorgeous! He’s an artist.
                          • PaulCDF
                            • Aug 2019
                            • 1435
                            Wow and Good And FAST hasn't even been a month. Happy it worked out for you!
