New clutch plates
  • lux
    • Aug 2017
    • 35
    New clutch plates
    I just put in a new set of KiwiIndian EZ clutch discs in my 741. It shifts much better, but I still get a very small bit of grind noise when shifting into 1st. Is this normal and if not what should I do?
    • 4769
    It is a crashbox (sliding gear) transmission, so minor grinding noise is normal. Judicious use of throttle blip and a quick shift remove most if not all, a learned procedure.
      • 957
      Try retarding spark to get lowest idle and rock the bike forward as you engage first.But as mentioned some crunch is normal.
      • lux
        • Aug 2017
        • 35
        Thanks guys, I kinda figured that was the case.
