Indian 841 – ignition – rotor and points
  • Coolbreeze
    Long Rider
    • Aug 2007
    • 320
    Today, I picked up a Prestolite rotor with “4-11” and “IG-1657RA” on the box. I also got a set of points with “1-45V”; “IGS-2224LB”; and “1DT” on its box.
    What do you think - should these work on my Indian 841?
    George Tinkham
    Springfield, IL
    www.virmc.com
    AMCA # 1494
    1941 Indian 841
    1948 Indian Chief
    1956 H-D KHK
    1960 CH
    1964 BMW R69S
    1984 Moto Guzzi V65Sp
  • bikerdds
    • Mar 2010
    • 205
    George, you need to check with Drew Crafton. He has had some of the correct rotors and caps. They are different than anything else Indian ever used and not readily available. The rotor in particular is and extreme version of the hammerhead rotor usually used in that the arms are even longer. I don't know the parts numbers to compare to what you got, but 841 motors can be finicky without the right stuff.
