Cory...sent you an e-mail regarding welding.
Powerplus
I haven't made much progress lately and have yet to build a puller for the oil pump gear. So, tonight I thought I'd see if I could get a spark out of the mag. I turned it over by hand and couldn't see anything so I gave the points a bit of a cleaning and lo and behold there was spark!!! Yee Haw!!! The camera couldn't capture it with the flash on but when turned off it caught it! I guess I should take a look inside the Schebler next.
Cory Othen
Membership#10953
I've been pondering the gas tank for a bit and thought I'd consult the masses to see what solutions might come of it. There's a split at the seam near the rear of the tank and I'm of the mind that I may have to take it apart for a re-do. Any thoughts? Thanks in advance.
Cory Othen
Membership#10953
I sure would Cory, you want to know its good to go best you can. I think taking it apart is the only way. Lots of leaky tanks out there. I have to do some of the same on a 101 tank project I am going to be doing. Interested in any tips you git also, Tom.
