oil for Ace?
  • almostarancho
    • Jun 2008
    • 1
    oil for Ace?
    What oil is best for the Ace four?
  • Ken Lee
    • Aug 2001
    • 298
    Hello 'almostarancho' , I use 15-40 deisel oil as I do in my Hendersons , there is a good discussion on oils for fours on the < www.hendersonkj.com > site at forum number 895
    worth a look , but it's like all these sorts of questions , you ask 12 people and you'll get 12 different answers , hope this helps , Ken
    Ken
    • Daniel Boone
      • Feb 2010
      • 14
      ACE oil
      Hi
      Is it a splash feed or a pressure feed motor?
      • Ken Lee
        • Aug 2001
        • 298
        Helo Daniel ,
        Both my ACE and Henderson are force feed , do not know about almostarancho's ACE but I would use the same oil but have a look at the HendersonKJ site on oils , it's a very interesting discussion . Do you have any specific reason to ask ? Cheers , Ken
        Ken
        • Daniel Boone
          • Feb 2010
          • 14
          Re Splash Feed ACE oiling
          Hi Ken
          My reason for asking if it was splash feed or pressure feed, was that on my 1922 ACE which is splash feed I found that some oils foamed out the spray bar when I tested my pump system. I had the sump off the motor and drove the pump with a battery drill as a oil test. The oil I choose to use after testing was 10W-30 SAE AMSOIL Small engine oil Commercial Grade Synthetic. I have done about 1000 miles with out any issues.
          Cheers
          Alastair
          • Ken Lee
            • Aug 2001
            • 298
            it's always interesting to hear others views and findings on oil , just because we use different oils on similar engines doesn't mean one of us uses the wrong oil , I'm sure other riders use different to us and all have good service , hope you continue to pile on the miles and enjoy a great and reliable bike , Ken !
            Ken
            • partshunt
              • 285
              Hendersom oil Site?
              I could not find that Henderson Oil Site? Where is it? thanks...Joe
              Joe AMCA# 3435
              • Ken Lee
                • Aug 2001
                • 298
                Hello Joe , Look on - http://www.hendersonkj.com/kjex/index.html - the oil discusion starts at number 895 , best of luck , Ken
                Ken
