Can anyone tell me if rocker towers are available for a '39 Indian Four? I found some mention on virtual Indian that said Jeff Hiatt was making them, but the links to his contact information seem to be under construction. Also, I was curious what the price might be. Thanks!
39 four rocker tower
Tags: None
thanks perry
Perry,
Thank you very much for the information. It was correct and very helpful! I ordered the part from Guy Henderson on Tuesday and it arrived on Saturday. The fit was perfect. He also supplied new bolts for the rockers to pivot on as they are the cause of this failure. In fact, I discovered that even though cylinders one and two had not failed, they did both have their bolts broken. I was able to reassemble everything and had it running again Sunday. Hopefully many of you will read this post and learn that this rocker clevis is available, because other respected sources told me that they weren't aware of anyone manufacturing this part. It was an absolute steal for $100. Thanks again, Matt
