Idle speed and max RPM for my 1941 Four
  • kustomizer
    Old Member
    • Sep 2018
    • 58
    I will be taking apart my engine before too long as I only have 20lbs of compression in 2 cylinders and the clutch doesn't work ( I bought it that way), I believe it to be a low milage original and with the timing cover off everything I can see inside seems to support that. I am interested in knowing the Idle and max speed of this engine but these numbers are illuding my efforts so far, do any of you know?. I guess if it was a Jeep from that erra it would be 500-600 idle and 4000 ish max?
    “People who say it cannot be done, should not interrupt those who are doing it” ― Bernard Shaw
