started my 1940 indian 4 after a winter in the house, cleaned out everthing, charged the battery, and fired it up and no matter how i adjust the carb it chokes out when i advance the throttle , it ran great last fall, any suggestions would be greatly appreciated, thanks chris
carb chokes out
choke out
well, i found the problem ,when i was running it before i was using the left tank, after cleaning everything , adjusting timing, clean needle etc, i added gas to the right tank and opened the valve and was able to adjust the carb, and it runs fine, aparently there is blockage in the left side line. thanks for all the tips, up and running again, thanks chris
Woooooo.... kunzog was the grand winner on that action. Good job! Anyone soldered brass mesh filter screens into the top of your petcocks for filters - eg. british bikes. If your tanks are not coated. I'd be thinking about doing it.
May greatly extend the life of your petcock.
Ive been there a million times! Glad it was easy ! Enjoy
