What is the correct carb for a 440 and what would be the initial settings on the high and low speed needles? Thanks!
1940 carburetor
Dec241949!
The carb was a Schebler DLX124, and for initial needle settings I would suggest 1 3/8 turns out on the highspeed, and 4 turns out on the low.
Since the manifolds are impractical to leaktest properly, your results may vary...
.....CottenLast edited by T. Cotten; 03-23-2015, 08:26 AM.AMCA #776
