Four clutch
  • Indiantim
    • Mar 2011
    • 61
    Four clutch
    Help guys please,
    Thought I was on the home run on my '36 four motor. Fitted 16 clutch springs with a King Clutch, can lever the release bearing with 2 tire levers, but when I try to operate the clutch by the fitted lever with a piece of tube over it can't get any sign of lift from the pressure plate. Don't want to try too much force and break something.
    Regards
    Tim
    '36 four. '44 Chief & sidecar. '28 Scout. '67 XLCH. '70 BSA. and a Guzzi...............
  • harleytoprock
    • Apr 2003
    • 374
    The trick set up when using the King Clutch is to use only 8 springs.
