I'd like to hear your suggestions and ideas on how to seal the kickstart shaft on a Indian Four. Thanks!
Need kicker shaft seal ideas
Tags: None
Can you post some pictures? How is it assembled? Bushed? Post some pix and there is probably a time-tested solution out there.
Cheers,
Sirhr
I have cosidered sealing the kickstarter shaft also. My thinking is that there is enough room to counter bore the shaft housing enough to take a narrow lip seal. The shaft is a standard size and seal dimentions are all listed in the seal books like "National" so it is certaintly doable and a good idea...JoeJoe AMCA# 3435
