lacing 18" 1940 wheels
  • dane
    • Jul 2007
    • 62
    Having trouble lacing the wheels on my 40 four. There are two different length spokes for the offset. Not sure what the offset is supposed to be and cant seem to get pattern right. The pattern for the later 16" wheels will not work on the 18's. Any help is appreciated.
    • 6018
    I know where you're comming from. I have had the most trouble with Indian wheels. All I can say is; the problem has always been with me but I've never had to make more than 3 tries at a wheel to get it laced. I believe the pattern would be the same for an 18" and 16" wheel. As for the offset; I would true the rim in the fork and frame so you get it centered to your machine.
    • dane
      • Jul 2007
      • 62
      Dimple patterns different 16 to 18. Unlike the 16's it looks as though the inner spokes run in the same direction on the 18's from the pictures I've located. Thanks for any further input
      • Knotthed
        • Jul 2008
        • 195
        See if this helps, if not I could send a picture of a laced 18" wheel - not a 40 but prior(I think they would be the same 37-45 interchangeable).
        Part 1
        http://virtualindian.org/6techwheels.htm
        Part 2
        http://virtualindian.org/8techwheels.htm
        D.J. Knott
        AMCA #10930
        • dane
          • Jul 2007
          • 62
          Thanks but that was where I started. That pattern is for the later rims.
            • 6018
            This is a picture of a 1941 four with 18" rims. It's a standard cross 4 pattern and the outside spokes point to the right.
              • 1675
              • dane
                • Jul 2007
                • 62
                Thanks all for the photos. Looks like inners both point in same direction unlike the 16's. Will try and let you know.
                • PRG
                  • Nov 2006
                  • 612
                  Howdy Dane,
                  My machine came with original spokes laced to 18inch Honda rims which I changed to originals. Though my pattern is the reverse of the 441 police machine advertisement posted by exeric, the final layout is the same with inners on both sides pointed in the same direction.
                  Folks lacing pre-46 wheels for the first time may not be aware that some spoke bending is required. The hub flanges are straight rather than curved inward and with such severe hub offset on the side opposite the brake drum, as well as the outer spokes fouling the spoke heads of the inners where they cross, these outers will not lay flat and must be bent to even preliminarily lace the wheel much less center the rim. That bending point right above the end of the single butted shank.
                  Cheerio,
                  Peter
                  #6510
                  • dane
                    • Jul 2007
                    • 62
                    Thanks. Great info from all and finally got it right. Wheels came out sweet.
