Safest Fuel for Indian Fours.
  • partshunt
    • 285
    Has anyone have a prefference on fuel grade for these old Indian Fours, 89 Octane or should a lower Octane be more suitable to prevent overheat? It seems the higher the Octane, the slower the burn. Just tryibg to run the engine in the coolest conditions. Ant preferences anyone?...Joe
    Joe AMCA# 3435
  • D.A.Bagin
    • Jan 2008
    • 595
    I usually use mid-grade 89. I try to ride something else if it is over 75-80 degrees out
    • Tom Lovejoy
      • Aug 2006
      • 951
      I run low grade regular for 13 years now in my Henderson, seem's good. Never could tell a difference if I payed more for premium, it runs fine with either/ about the same temps too I believe, good luck with yours.
      • partshunt
        • 285
        Thanks guys, Just askin, burnt a big hole in #4 piston, carb possibly went lean the last ten or twenty miles, No manifold leaks found. Its a 29 Four, troubleshooting cause is all..last fill up was 89 Octane, shoulda maybe stayed with regular fuel possibly.......Joe
        Joe AMCA# 3435
          • Feb 2003
          • 5353
          Joe!!! Sorry to hear about your '29. Here's hoping you have it back on the road soon. The weather is just getting good!!!
          Cory Othen
          Membership#10953
          • partshunt
            • 285
            Well Cory, you know what they say, "want some grief, buy a Chief, want more? Get a Four". She blew her guts on the freeway in four lanes of traffic, could not pull over and I think all those cars in the mirror wanted to run over me when the bike lost speed and slowed er down a bit on three cylinders. It blew out the dipstick due to combustion in the crankcase, raw fuel from number 4 cylinder lighting up downstairs below. About four explosions and lost about 1/2 my oil before I got er stopped. To think, it ran so sweet, no warning sign. The engine is apart on the bench and there is still oil dripping off the chasis. Its well splattered with oil. I have a piston coming in the mail and some other tid bits.....sucks, disapointing but ya gotta go on...Joe
            Joe AMCA# 3435
            • Robin--M
              • May 2011
              • 23
              Hi Joe,
              Sorry to hear about your problem. I've been riding Indian fours for almost 40 years. Read your original manuals and do not set your carb too lean. That's the biggest problem that most people do on Indian fours. They will run good even when they are too lean and then you burn a whole in the piston. The 87 octane will work fine. Remember, back then those bikes were new, they didn't have high octane.
              Robin Markey
              Bob's Indian Sales & Service
              • Tom Lovejoy
                • Aug 2006
                • 951
                Not a mechanic at all, but that's what I have always been told. Just like Bob said, they well run fine to lean and I have been told. When not pushed things and or problems don't show themself's, but push the speed up and hold it at all and the problems well show itself quickly. With the serious issues you showed, sure sorry to hear it though. Better to blow alittle black smoke than to lean. Just git it where you see alittle black smoke when hit the gas hard, but not back firing. That's what I have done with good results, best of luck.
                • Tom Lovejoy
                  • Aug 2006
                  • 951
                  Hey Joe, if I was you and had that experience - I would still be shaking, let alone would of wet myself :-) I have had my Henderson on the freeway here in L.A twice for only a couple miles, it ran like the wind and felt fine. But I thought if I did this very often, both my Deluxe and I would not live long. I stay off the freeway and just cruise along, it feels like it will last forever when running that way :-)
                  • partshunt
                    • 285
                    Tom and Robin:- I surely heed your advise in all aspects. I had thought the settings on the carb were pretty close to what they should be, however, I will keep a keener eye on it for a richer mix next time out. . And like you say, a little black smoke would possibly saved my butt. I never was comfortable on the freeway with it. seems to be sceaming too hi a rev. Its running 18 and 40 tooth sprockets and 400 X 18 wheels. Sounds close to right to me but I dont know the RPM at 55 MPH. Can anyone calculate or estimate what the revs might be at 55 or 60 MPH?...Joe
                    Joe AMCA# 3435
                    • partshunt
                      • 285
                      I have parts coming to repair this lame four but some I cant find so far. who makes the gaskets for the early fours in my year model 1929, it has the smaller exhaust manifold flange, (1.75" bolt space) and I need a set of 4 manifold gaskets for that. Also looking for pinion shims and the ball thrust large and small misc shims. need to reshim it a bit, reduce crank and bevel gear backlash. Any info on a source would help me a lot and be much apreciated...Thank you all in advance....Joe
                      Joe AMCA# 3435
                      • yhprum
                        • Dec 2006
                        • 50
                        I'm not sure if high gear is 1:1 but I calculated my J model by measuring the tire circumference in feet then dividing that by feet per second at a given speed (that tells you the tire RPM) then dividing that by the final drive ratio if that makes sense.
                        MPH Feet Per Min
                        100 8800
                        90 7920
                        80 7040
                        70 6160
                        60 5280
                        50 4400
                        40 3520
                        30 2640
                        20 1760
                        Steve
                        • bikerdds
                          • Mar 2010
                          • 205
                          Joe, I would also look for sources of ethanol free fuel. Unfortunately, California has few places. Look up ethanol free fuel on the net.
                          • tomfiii
                            • Jun 2007
                            • 314
                            I have found several conversions to use for speed x rpm.
                            BAKER Drivetrain offers custom Harley-Davidson transmissions and parts.
                            Find information, resources and relevant links for bikerenews.com. This domain may be for sale.
                              • 1675
                              Here's one:
                              Pure-gas.org is the definitive web site listing stations that sell pure gasoline in the U.S. and Canada.
                              I also wonder if marinas are a good place to find ethanol free gas, given how much trouble ethanol gives to boat engines.
