Lower bearing for steering head tube on 1946 Chief
    • 1676
    I am looking at the head tube on my '46 Chief frame, bottom's up where the lower bearing for the crown sets in... and to me it looks like there is a bearing race pressed in there. But when I look at the parts diagrams or the service manual there is no separate bearing race showing for post 1945 models. Take a look at this photo and see what I mean. Is there a separate bearing race or is it just cast in a way that is fooling me?
  • Bills37
    • Jan 2010
    • 247
    Sure looks like a race to me. The bearings in my trans are that way. It might be just the style of bearing that someone put in there. You can get a lot of bearings with the same dimensions but with thrust in one direction/ both direction / shielded etc.
    • indianut
      • Feb 2005
      • 308
      It looks like the Remains of an old bearing. Take it out and install a new bearing.
      http://laughingindian.com/
      A.M.C.A. Member Since 1986
      • Bills37
        • Jan 2010
        • 247
        Does the bearing look like this?
          • 1676
          I actually don't even have the bearing to compare, that's why I was curious. (Since a 1946 calls for a sealed bearing I was curious if for some reason what I was looking at was an older loose ball type bearing. It doesn't look like the race from a sealed bearing, but it probably is.) I'll just pop it out and go with a new sealed one. Thanks for the input!
          • Bills37
            • Jan 2010
            • 247
            Run a bead with a welding rod around the inside of the brg. race and let cool. It will fall right out.
