We used to call UHMW, 'oompie'. Made miles of conveyor guide rails, dead plates, and escapements with it. I also liberated a lot of UHMW scrap for lavaliers, framistans, and what-nots.
My Bobber fell over...
Thanks to everyone. I now have a better perspective of the challenge before me with the bars.
I do have some help from the machinist who built one of my motors, he's an Indian guy, so that helps my apprehensive concerns.
The bend is slight, not severe. But I know sometimes looks can be deceiving, but with the guidance and suggestions from you all, I'm better prepared
for the job. Thank again for all the help. Roger
Looks like McMaster-Carr has UHMW in various forms maybe something like this film?
polyethylene | McMaster-Carr
Roger, as Tom suggested, I would go the chopper riser route for equal mechanical reasons, and most important; economy. Generally, in my experience, sheet metal, and tubing steel wants to go back to the form it was originally forced into. That is a very generalized opinion, and many factors like heat, and force come into play, but with careful observation, and gentle manipulation, badly mangled steel will cooperate.
Thank You Gentlemen, for the responses. I should have included this next paragraph. The right side bar isn't too badly bent. Its just that I've straightened it before. I felt I should ask the experts
before I attempted to bite off more than I could chew. The new information (to me) is a great addition to my meager skill set.
I want to add that I had planned to put the Bobber on my M/C trailer, with ratchet type tie-downs used to secure the front end, so there will be NO twisting, and the front wheel secured with another set of tie-downs. I also planned to brace the front end with cut-to-length wooden 2x4'S to help cross brace the entire front end. The M/C will be firmly secured, tied down in every possible way to avoid any twisting or bending except for the singular right side bar. Measuring the bars in several spots along the length of the bars so as to get front, side, and oblique angle views.
The height at the end of the bars to the floor, both throttle and spark advance should be the same on each side. I can put the M/C on the trailer, squarely, with levels and a plumb bob.
I've done that much before. I feel pretty confident I'll be OK, I wanted to ask the experts for advice and learn a different way to approach this task.
All of the above remedies are great advice, and much appreciated. I've got plenty of "Low-Tech", quite a bit of "Instinct" too. Its the "Patience" part that I need more of !!
Thank Again Everyone, Roger
The dull recesses of my mind kept spinning and I looked back:
Ted Borman did an article on handlebar repair on 1919 HD in the May/June 2022 issue.
(Bars in this case were likely damaged more than C2Ks'
Spring 2001 Issue Steve Blanchard presents an idea for "Getting kinks out of handlebars"
Much the same as what Eric suggests above. Good suggestion but boring a 1" hole in steel blocks is likely beyond
my China Bob drill press (Aluminum might be possible but I like the idea of finding some used chopper risers even better)
PS
In the Spring 2001 issue there is also a tech tip on Obsolete Heli-coils by Tom Cotten)
Neither did I, Eric!Originally posted by exeric View PostI never thought of molding lead into dies, Tom. .
I just used blocks of lead, and let them shape themselves.
(Should have saved the Lyman ingots.)
PS: Admittedly, I have used lead flashing and sheet to cushion everything everything from pliers to vises to chrome valve cover wrenches.
Here's an impression of the side of carburetor I needed to "straighten":
It might have been a wheel weight.
I never thought of molding lead into dies, Tom. You are a wealth of humbling, and excellent information.
Lot of trouble, Eric,..Originally posted by exeric View PostAlong the lines of what Cotten shows, I've bored a 1" hole on the parting line of 2 hunks of steel to create a die. ....
When that's the same as a common chopper riser out of the milk crate.
I've been meaning to pool all my lead into a fresh pillow, but I hate to melt good fishing sinkers.
Are they illegal yet?
Along the lines of what Cotten shows, I've bored a 1" hole on the parting line of 2 hunks of steel to create a die. I use this die assy. in a hydraulic press and can take small kinks out of 1" tubing, or use the die in the press to anchor, and then persuade a frame, fork, or handlebars to bend, as needed with all manner of persuaders. I've made a lot of these dies of different lengths, bores, and filed-in curves to suit whatever problem. The dies work great for nickel plated, or chromed handlebars to minimize abrasions, or cracks in the plating. Aluminum dies also work good, and more gentle on plated parts.
Imagine this swingarm is your handlebars, C2K,..
Held by the press at the flat in the middle, so then each bar can be compared by their height and position over the base plate for reference. Bars can be pryed upward, or jacked downward, or levered oblique.
Immobilization is the whole thing.
Harley made bending bar part #96806-40 used for straightening bars and frames which can come in handy if you can get your hands on one.
I have a pair of 741 handlebars that are bent so I would be interested as well. My 741 is basically a parts pile so handlebars are not on bike.
I wonder if Ted Borman AMCA Tech Editor Nuts and Bolts column might have some advice? I enjoy his column:
AMCATechEditor@gmail.com
"Shade Tree" mechanics is great but I tend to go down hill into "Primative Pete" pretty quick with not stellar results.
Where did I put that bigger hammer?
