anyone know how to take apart a 1940's Indian gas cap for chrome plating? Or will the vents still work if the whole thing is plated? Thanks
gas cap chrome plating
Bryon....I'm no expert because I've not done this, but you notice the chrome piece is more or less a shell crimped over an inner cap that has the vent mechanism. Guess it would be feasible to expand the crimp and separate the two cap pieces.
The hole is important to keep clear, and having the cap chromed properly would be labor intensive because you'd want to etch or clean out all the knurling around the perimeter of the cap or else they'd fill in and your original cap would then look like a reproduction. That's all I got!Pisten Bully is Harry Roberts in Vermont.
I got the gas caps back from chrome plating. I think they came out pretty good. I had to clean up the vent holes with a drill bit and work the inner plunger back and forth a bit to get them moving but they seem to vent properly when I blow through them. Time will tell! Here are pics of before and after the chrome shop.You do not have permission to view this gallery.
This gallery has 5 photos.
- 3 likes
That was quick! Thanks for the follow up. Great to hear it worked out.Jason Zerbini
#21594
