1947 Chief rear shock removal
  • TChief
    • Aug 2018
    • 12
    Does anyone have a diagram of the inside of the 47 shocks and a list of how to remove the shocks? I want to replace the chrome outer covers. I appreciate any help! THANKS TCHIEF
  • Green Indian
    • Apr 2014
    • 303
    Kiwi has a YouTube video:
    AMCA # 3233
    • TChief
      • Aug 2018
      • 12
      The video shows once the shock is off the bike, I would like to know how to take off the frame to get it to the vice. I appreciate the link. THANKS JEFF
      • PaulCDF
        • Aug 2019
        • 1423
        Here you go courtesy of Jerry Geer:
          • 965
          looking at the greer pic 15 gets unscrewed from frame and then a special plunger removal tool is screwed in to the bottom of 4 where 12 was,then tightened to compress spring,allowing assembly removal.
          They probably list tool also
          • PaulCDF
            • Aug 2019
            • 1423
            Ditto what Tom said plus #20 is a small set screw that holds upper chrome cover.
            • RonH
              • Jan 2016
              • 213
              This is the tool you need to remove the shock from the frame. Screenshot 2024-02-21 at 7.36.26 PM.png
              • FLFD7
                • Feb 2021
                • 737
                Make your own tool.....
                Long bolt, nut and washers, piece of pipe for spacer, screw bolt into bottom of bottom of shock rod, hold bolt and turn nut down which pulls the shock rod down into the spacer and shortens up the amount the top of the spring rod extends from shock body. This gives you the clearance you need to swing the shock into or out of the casting. Now loosen the nut and the spring rod extends and you can remove the tool.
                Hope this helps.
                Note: pictures are a Sport Scout, same thing for Chief. From memory I think the bolt is 7/16-20 for Scout, 1/2-20 for Chief
                Joe
                • hairynob24
                  • Feb 2011
                  • 347
                  The set screw in the upper frame casting can be a bitch if its sized
