Mag vs Distributor? Indian Chief
    • 8236
    Originally posted by Fastfred116 View Post
    Thank you everyone for the responses. I apologize for the confusion. You are 100% correct with all the reasons why I have had problems. I used a old photo here. Things i have done. 1. Install a new cap. 2. Installed a new rotor. 3. Installed new points. 4. Adjusted the chain guard so the kicker didn't hit. 5. Installed new wires. 6. added a Thorcap to the condenser. .... I was able to get it running but it took a lot of kicks. 20-50. I'm a big fat guy. It will not end well if i keep trying. But a friend called over the weekend with a idea I want to try. To trick the mag. See if it runs with a battery.
    It should make you think, Fred,...
    Something other than the mag isn't in order.
    Before kicking gives you a heart attack,
    Please review http://virtualindian.org/11techleaktest.html
    • Fastfred116
      Cape Cod Indian Rider
      • Jan 2022
      • 46
      I did get the plate from you to test the intake. I just need to set it up. I am planning on doing that. Also, I do have an old cap to the mag I could drill out. Enfield Ricing makes a nice one. I also got my rotor from them. I do like the look of the old mag.
      Fred Leach
      Cape Cod Ma.
      1946 Indian Chief
      1947 Indian Chief Roadmaster Bonni
      2014 Indian #450 Chieftain
      2013 Vic Vision
