chief aftermarket clutch
    • 971
    Im working on the clutch for an 80"chief that has some slipping under max load with original syle clutch.I was going to change out one of 1/8 disks to another 3/16 but I also have a Greer clutch(I think that was supplier) on the self that I am going to install instead.
    The friction plates have black steel with brown cross hatched friction material bonded to each side.
    I seem to recall some discussion of people running less than the full 16 springs on this assembly.
    Anyone familiar with this clutch ?Any feedback would be appreciated.
  • PaulCDF
    • Aug 2019
    • 1438
    Tom;
    Here is a link to previous discussion on the issue:
    Clutch sliipage on '53 Chief. - AMCA Forum (antiquemotorcycle.org)
    I think clutch slippage would be greater with less springs. Or said another way more springs less slippage.
      • 971
      Thanks,that discussion did have some reminders to check hole to stud clearance on the friction discs.
      I realize less springs would not be good for stock clutch but the repro may be different.I will probably just put in all 16 and check it out.
      • Skirted
        • Sep 2012
        • 710
        I've been running 12 springs with a Charles Qua sinterbronze clutch for a few years. Ride two-up often in mountains. Never a hint of slippage and very consistent release and engage
        Jason Zerbini
        #21594
          • 971
          Thanks Skirted.I remember when that clutch came out,but I only eveer had the stock set ups,with no problems.
          I did see the King clutch was mentioned as ok with 12 springs.This greer clutch is similar.
