timing chief 74"
  • cscott
    • Oct 2002
    • 451
    timing chief 74"
    could someone tell me how many degrees before top dead center the $ mark is on the flywheel and is there any difference between the two half's of the flywheels? thanks
    • 964
    Check out Jim Moshers
    Performanceindian under Indian ignitions.Lotsof good info.
    The right side wheel is drilled for oil passage
    • cscott
      • Oct 2002
      • 451
      thanks Tom where do i find that? thanks
      • Skirted
        • Sep 2012
        • 705
        Here you go
        Says about 38 degrees
        Jason Zerbini
        #21594
          • 964
          That it.lotsof good info from a guy with a dyno and exhaustsensors and land speed record for his twin engine scout.
          His whole website is a great read for an Indian owner
          • cscott
            • Oct 2002
            • 451
            so i have an engine without flywheel marks i need to know how to find tdc and have it accurate ,,, any ideas dont want to pull the head, thanks
              • 8231
              The most accurate way I found, Chris,...
              Was to fit very small tubing to a 14mm sparkplug fitting:
              With the piston close to TDC, a drop of oil can be introduced at the end by wrenching the crank backwards slightly, and then cranking slowly forward it can be observed to rise and fall with the piston, and TDC can then be marked with precision.
              • cscott
                • Oct 2002
                • 451
                thanks again Tom
                  • 964
                  once you determine tdc and your desired full advance point using Cottens method,borascope for smartphone etc. I would remove the breather tube elbow and make a center punch mark for future.
                  Maybe there is one already there.
                  • Roadhome
                    • Dec 2021
                    • 32
                    That's brilliant!
                    • tomfiii
                      • Jun 2007
                      • 314
                      but here's another little timing trick you can do.
                      When the exhaust valve on the rear cylinder just closes....the front cylinder fires.
                      Slowly turn your engine over, the moment you can spin the rear exhaust lifter as it's closing ...
                      set your distributor to fire on the front cyl.....at full advance.
